跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
Headphone amp is not working?
I have this Mac as my daily driver, and I regularly use the headphone jack. About a month ago there was crackling in the headphone jack only, and it has progressively gotten worse. It is not a grounding issue, since I've tried grounding the computer several different ways. The crackling is not present on powered devices like speakers, but for devices that rely on power from the port, like earbuds and headphones, the crackling is very noticeable. This has led me to the conclusion that the headphone amp is defective. Is this a board level repair?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
As long as you are sure it is not an issue with the devices you are plugging in, the issue will be with the headphone jack itself. Check inside to make sure there is no dust, since this will also cause crackling.
Replacing the jack is not easy, the part cannot be bought new either and has to be desoldered from another board. Call around to see if anyone will be able to replace this, but this type of repair is usually turned away by most repair shops.
这个答案有帮助吗?
得分 3
4条评论:
Couldn't it be a bad resistor or shorted cap attached to the jack lines? Or that would not cause crackling?
完成的
@rany if this was the case, I would have thought it would short the whole line to ground, meaning no sound. Whenever I have seen headphone crackle (Macs, iPhones, iPads, etc) it has been resolved by replacing the headphone jack. The jack itself is grounded through the soldering to the board, so I don't think it is a grounding issue either.
完成的
Thanks @reecee, I don't have much experience with headphones jacks, haven't seen them much, so I'm asking.
完成的
@rany I haven't had a lot for headphone issues before either, usually just work on them ones as an extra on top of another repair, I don't like to get these in just for headphone issues, they are not fun :/
完成的
添加一条评论
添加你的答案
Seji the veggie 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 6
总计 380
