跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
LCD stays dark after replacement at cold start, swap shows image
Hello, we are a professional repair company located in switzerland with 17 branches nationwide. we recently noticed something very strange with display replacements at the iphone 6 Plus where we just can't get to the bottom of the issue. the situation is as follows: An employee of ours used a iphone 6 plus replacement screen and mounted it on an iphone 6 plus that had a broken screen. after unhooking the battery he mounted the replacement screen, attached the vbattery again, tried to start, and nothing happened. so trying to figure out what was wrong, he disconnected the battery again, removed the replacement screen, attached the old screen that had a broken glas, reconnected the battery, tried to boot and voila there is the apple logo again. He then checked the same replacement displays with three other phones and the lcd never lit up. so assuming the display was defective he sent it do headquarters, where we hooked it up to our screen tester, there the lcd showed up just fine. we returned the apparently functioning screen back to him where he tried to use it with another customers phone. he then noticed that if he attaches this replacement screen to an iphone if it booted up with a damaged screen and then swapped it "hot" while the battery was still connected to the logic board, the lcd would show a picture and would work properly. if he then would turn of the power and reboot the display would not show any image again.
however if he would use old broken screens on the same phone he could restart them every time with the lcd showing an image, but he could only get the replacement screen to work if we would boot with an original screen and then swap it. does anyone have any explanation why that is?
On a sidenote, we take great care in sourcing our replacement parts in china, we visit twice a year, inspect the sellers factories, and are quite picky with quality. our return rate so far has been below 1.5%. since we are so focused on quality we want to get to the bottom of it, since we cannot figure out why the screen would only work when swapping it on a turned on phone ( which basically is against all the rules in the guidebook, since the risk of damaging the logicboard is there).
any input from you guys is greatly appreciated! thank you
Update (05/14/2017)
Well the thing is, it is this particular repair guy that is having issues with our screens, all the other repair shops are not experiencing these issues. i am still unable to tell, what they are doing different with regards to the procedure in comparison to the others. Do you have any experience regarding the repair procedure that deems screens unusable due to an error some repairshops make? thank you for the answer... unfortunately being swiss does not help us with this one :-)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
The phone is probably rejecting the screen because of an issue, try a different, good screen and see if that works.
完成的
添加一条评论
2个答案
已选择的解决方案
I think this is a question that you should be asking your supplier. It sounds like you have a good relationship with them. They would be the experts in how the screen is assembled.
It appears you are doing everything right (and besides, your Swiss ;>). There is clearly something wrong with this particular screen and I don't think you should be spending so much time trying to understand why it doesn't work when you aren't the one who is doing the refurbishment.
这个答案有帮助吗?
得分 3
2条评论:
I re-read your question to make sure I didn't miss anything...you only talk about one bad screen, not several, hence my answer not to waste time trying to understand what is wrong with one screen.
If there are multiple screen issues with this one employee, I would send someone to watch over his/her shoulder to see what he/she is doing differently from all the others.
完成的
thank you minho, well it is several screens with that one particular repair shop. I watched over his shoulder last saturday and everything seemed according to our standards and guides. that is why i cannot get to the bottom of it. I simply cannot reproduce the issue.
完成的
添加一条评论
I have had this once a it was because the extension flex cable from the home button was torn. Have you tried a new flex or home button to check if the iPhone will start normal?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mobilerevolution partners 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 92
