跳转到主内容
Repair and disassembly guides for the Jura (Capresso) Impressa Series J coffee maker.
23 个问题 查看全部
Coffee beans in coffee bypass
Aged mother poured coffee beans into coffee bypass. Now what?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
dude your aged mother is killing your machine. First of all, forbid access to not make problem worse! What's next? She'll put eggs there thinking it's a blender. seriously.
secondly, it's best to take the beans out. the way it works is it directly puts the ground (in your case not) beans into the brew assy. There's a piston w/ a metal filter. If you run as is it could bend the metal part.
Turn the machine upside down and give it a good shake. That's the lazy way.
If you wanna be thorough, take off the brew group and empty it out by hand. This way you'll know for sure it's empty. If you not lazy, good chance to clean it. It's prolly disgusting, as you'll see.
完成的
添加一条评论
1个答案
Open it. Jura Capresso IMPRESSA J5 öffnen. Clean it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
hopskater 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 174
