跳转到主内容
带13寸显示屏的 MacBook Air 机型
3666 个问题 查看全部
MacBook not turning on. No charging light on MagSafe.
Issue:
  • Macbook Air (13", A1466) not powering up
  • No charging light on MagSafe
  • No sounds, not even fan
  • Screen will occasionally come on displaying charging symbol or low power symbol
Things tried:
  • SMC reset
  • Disconnecting and reconnecting battery
  • Different charger (non-official but working)
  • Cleaning charging port
Okay, so firstly this is not my MacBook Air and nor do I know much about them, so please keep things simple. This is my friends device, he said it was being used as normal and then it suddenly switched off and never powered up again - the battery was apparently at 40% at the time.
I have tried all the above fixes with no success so far. Upon trying a new charger the charging light initially turned orange before going off again, this makes me think that there is some kind of charging issue. Also the screen occasionally shows that the device is charging before quickly going off again.
Is the issue the charging port, the battery or perhaps something else. Any help and direction would be kindly appreciated as I'm afraid I have little experience working with Macs.
Marty
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Try a new, known good DC-IN board and see if it starts charging. Also, look for previous water damage (stains, corrosion, etc.)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
martywild10 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 178
