跳转到主内容
Repair guides and troubleshooting for the Acer Aspire V5, a series of laptops on the Windows OS by Acer.
132 个问题 查看全部
Best way to repair bent battery prongs?
I recently replaced the ram in my Acer Aspire V5-552p-x404 laptop, and in doing so had to unplug the battery for safety. When plugging it back in, I believe the pins got bent, but can't figure out a good way to either bend them back or remove them if they aren't needed. I've looked online, but haven't found a guide on which pins are needed for the battery to function properly within the laptop. Does anyone have any suggestions on how to solve this or know which pins are needed to function properly?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Your best bet is to carefully bend the pins back in place.
All pins are needed. Some are power, some are ground and others are for the control circuits to make sure all cells in the battery are properly charged.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Luke Perrin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 11
总计 505
