跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Touch screen doesnt work after repair
I just repaired my iPhone 5 and the touch screen doesn't work, I've tried reconnecting it but that didn't work, is there a way to find out if the replacement is faulty or if i did something wrong
Update (05/12/2017)
just put the old one on and it works fine. i put the new one on again and it works fine at 90 degrees but when i put it in the phone it has trouble swiping and other issues
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Re-install your old screen (assuming it was cracked but functional). If the old one works, then you likely have a bad replacement screen.
这个答案有帮助吗?
得分 4
1条评论:
Damaged cable
完成的
添加一条评论
此回答最初是针对另一个问题
Its a common issue for iPhone OEM replacement screens to have touch faults similar to this.
I would first try testing all your connector to ensure that they are all in correctly then try again. If this doesnt work then you will need to order a new screen
这个答案有帮助吗?
得分 0
1条评论:
I find out that also trying to force the screen in causes this too.
Op have you made sure that the corners (dents) or edges of the iPhone housing aren't obstructing the screen from fitting in any way?
This greatly reduced the amount of screens that ended up faulty with ghost touch / touch dead spots.
Unfortunately when the screen starts doing this it ends up needing to be replaced with another screen. Sometimes it can be fixed by fixing up the housing to let the screen sit flat.
完成的
添加一条评论
添加你的答案
Tom Read 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 94
