跳转到主内容
Why are my apps force closing constantly?
When I go to setting and into apps ,all my apps are forced closed all the time. I need some to run in the background like macafee security and a call blocker but as soon as I exit them they're closed. Is there a way to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Thanks!! I realized there's a Restricted tab in my App Settings. I,had to uncheck a bunch of apps I need to keep running
完成的
添加一条评论
2个答案
已选择的解决方案
If I understand correctly, the problem is not Android force closing apps because of low memory (which would be showing the app not responding message constantly). It is that nothing continues to run in the background, because the system takes the liberty of "force closing" apps when you simply exit them or swipe them from the recent apps screen.
I believe the problem has to do with the software that ships with the phone. Unfortunately there doesn't seem to be a way to change this setting, and without unlocking the bootloader and installing a custom ROM, we're probably stuck.
这个答案有帮助吗?
得分 0
添加一条评论
The best thing for app closing issues is to try to force reboot the Phone by holding down the Power button and Home button until the device flashes the logo. Then let it boot back up and try to use the app again, it should work… if not keep reading on
这个答案有帮助吗?
得分 0
2条评论:
for a chromebook acer r11 there is mo home button
完成的
for a chromebook acer r11 there is no home button??
完成的
添加一条评论
添加你的答案
Erin Mitchell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 8,149
