跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
Problem with touchscreen after glued the frame
Hi everyone!
I have a major problem with the touchscreen on my iphone 5.The display was popped out a little so i tried to glue the frame with superglue.I forget the shield on back of display.Anyway,I did the job ,but i didn't see that it came out to much glue,and after i replaced the display the touchscreen doesn't work and sometimes i get white vertical/horizontal lines.Do you know a solution to remove the glue,or i need to separate the touchscreen from the LCD,and then to buy a new glass?
I have some photos:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
A new glass wont help as its just a piece of glass... Try removing the screen and clipping it back together onto the board, if that doesn't work then you need to change the screen.
Over stretching the flex cables at the top of the phone will damage the screen so its probably not the glue its the initial drop it had to cause the screen to lift out (or a swollen battery, pushing the screen out) or caused by pulling the screen to glue it.
这个答案有帮助吗?
得分 0
添加一条评论
Sounds like you damaged the screen when you glued it, id just replace the whole screen for a new one and not bother gluing it, they are so crazy cheap now its not even worth trying to repair.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dragosneagu95 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 321
