跳转到主内容
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
How to remove stripped logic board screw?
I recently followed the guide on replacing the hard drive in my mac mini.
I ended up being successful, however in attempting to loosen the logic board screw to allow room to to seat the hard drive as the instructions indicated, the screw was so tight I stripped the screw. After quite a lot of struggle I seemed to get the drive seated and it is functioning.
Is there a way to loosen the screw for any future issues?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If you have some of the head left then you can try and apply more pressure and turn the driver slowly.
If it is completely striped, then your options are pliers or drill.
If you can get needle nose pliers on the head and have enough grip to turn it, turn slowly, and be careful not to scrape the board.
You can also use a drill with a drill bit as close to the same size of the screw as possible and apply some, not a lot of pressure, straight down and use the lowest speed to slowly drill the head away, once the head is off you can remove the rest of the board and use pliers to remove the remaining screw.
这个答案有帮助吗?
得分 3
1条评论:
Thanks . I think I will wait until I need to attack that project if I have to.
The drive is installed and working as of now .
完成的
添加一条评论
如何卸下滑丝的螺丝
Theres a great guide on a few ways to do that.
这个答案有帮助吗?
得分 1
1条评论:
Impact driver set works well too. But that is last resort before going to cutting tool.
完成的
添加一条评论
添加你的答案
b biggs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 656
