跳转到主内容
加入维修社区 - 创建账户
Toyota released the 2002-2006 Camry XV30 series as a larger sedan in September 2001 for the 2002 model year.
The clutch will not engage at all I'm wondering is it a slave cylinder
2002 Toyota Camry CSI
The clutch when engaged or disengage with the purpl
The clutch does not drive the car forward and is not over reving & no clutch plate smell is coming from the gear box and I was wondering is it the slave cylinder buggered, or is the clutch that is needing replacing.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@timothymoad ,Timothy, Look to see if the pin from the clutch fork to the slave cylinder is sitting somewhat loose/has a little movement(not extended) when clutch peddle is not pushed, if some what free/movement then the slave is not stuck on and would suggest the problem lays further in the system. Probable clutch disc/pressure plate either worn or hanging up on bearing/fork. If things feel some what normal and the vehicle does not want to move,may be a broken CV joint on the axle. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Timothy Moad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 27
总计 1,962
