跳转到主内容
Samsung的旗舰手机,Galaxy S8,发布于2017年4月。
304 个问题 查看全部
问题已关闭
How to Recover Deleted Photos from Samsung Galaxy S8
Hi guys. I lost some photos from my Samsung Galaxy S8, tried some Android data recovery or similar apps, but failed to recover the deleted photos. Do you guys know any tool can really restore deleted photos from Samsung Galaxy S8? Thanks a lot.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
6条评论
I try the software in this page just now, and restore the photos from my S8, you can have a try.
http://www.photorescure.com/samsung-gala...
完成的
I do not think there is free software can really recover deleted photos from S8, for I have tried many android data recovery apps, in the end, I have to pay some money to purchase the liscense to activate the software so as to restore deleted photos.
完成的
Hello, you say you have used the Android Data Recovery software but it is not successful, is it because the software operation is too troublesome, or the software operation process is not detailed? In fact, Samsung photo recovery is very simple now, you may try this software Eelphone Android Data Recovery, easy to operate, detailed process introduction, and free download attempts. How to recover deleted photos from Samsung galaxy become easier.
完成的
tied some apps to retrieve deleted pictures from S8. Most can not only find the deleted pics, but also can export the existing data on device. Find this to get back lost photos from S8 is no longer difficult. https://goo.gl/bNC1jJ
完成的
Samsung Data Recovery can be the best solution for this problem,it allows user to get back deleted data without back up.When connecting your device to computer,the program will display all deleted files.You can restore what you want through a click.Really efficient!
完成的
显示更多的1条评论
添加一条评论
6个答案
已选择的解决方案
Hi, jesson. I think you can try this Android data recovery, which is able to restore lost photos from Galaxy S8.
1. Run the android data recovery, connect your S8 to the program
2. Enable USB debugging on your S8
3. Scan your phone
4. Preview and recover deleted photos from Samsung Galaxy S8
You can give it a try following the detailed guide there. Good luck.
这个答案有帮助吗?
得分 10
1条评论:
Another choice,https://www.fucosoft.com/android-data-re....
In fact, I recover my data through it, I hope it is helpful for you.
完成的
添加一条评论
If you have used some cloud storages such as Google photos and Dropbox, it will be super convenient to retrieve pictures from trash of such cloud drive. Next, I would take Google photos as an example to illustrate how to complete recover deleted photos from Samsung Galaxy S8.
1.Open Google Photos and tap on "Trash".
2.Select the deleted items that you feel like recovering.
3.Finally tap on the recover button at the upper right. Finished.
Note: Items in trash of Google Photos will be permanently deleted after 60 days, while Trash of Dropbox is only available in the webpage version and saves photos only for 30 days.
这个答案有帮助吗?
得分 4
添加一条评论
https://restore-samsung-contacts.blogspo...
There is a link on how to restore them.
Hope this works! If it did please hit accept answer!
这个答案有帮助吗?
得分 3
添加一条评论
I don't think that some third party software can recover deleted data from Samsung Galaxy S8 for now. According to my knowledge, it needs to root first, then the programs search for the deleted files. So you have to root your S8 first.
这个答案有帮助吗?
得分 1
添加一条评论
Go to the drop down menu, hit settings, then hit trash, the trash and the deleted items will be there if its been within 15 days since deleted. Just hit restore then your done. It worked on my s8
这个答案有帮助吗?
得分 0
添加一条评论
Download DiskDigger app.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 176,579
