跳转到主内容
D1760-2 DECT 6.0 Cordless Home phone with caller ID.
Recently started getting "Check TEL Line" on phones HELP!
Recently started getting "Check TEL Line" on the phone screens. Tried unplugging, resetting the modem, etc. Still shows up and no dial tone. Sounds like an open line though.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
3条评论
This is a ViOP phone. There is no physical line. Cold boot of base. Rebooted router. No luck.
完成的
I get no line what does this me
完成的
There are no"lines"! This is a VoIP phone.
完成的
添加一条评论
3个答案
最有帮助的答案
Try plugging the phones into a different line, if the issue persists, try an entire different phone, like a cheap one or maybe a really old phone if you still have one.
If nothing changes, call your service provider and see if they can come out and figure out your issue.
If this answered your question please hit the accept answer button!
这个答案有帮助吗?
得分 1
6条评论:
Why do you need to have a certain number of points before you can vote someone's answer down? If it is not helpful once you have tried it wouldn't the person who proposed it need to know that? Also, since you cannot get anyone at Uniden's customer Service on the telephone (they send you through voice mail and then hang up on you after telling you to go to their web-site), how are you suppose to get and answer to your problem?
完成的
Well the reason they do that, is sometimes there is spamming issues. like downvote attacks and spam and stuff like that. You need ~200 reputation to downvote. any questions you can ask on meta.ifixit.com you also lose 2 reputation when you downvote to prevent abuse.
完成的
Thank for the explanation, BUT it still does not answer the question about how to fix the telephone and get it working again.
完成的
I sent a message to Uniden customer support complaining about their customer support (or lack of) and received a message back concerning our problem. "Uniden no longer has live technical support and parts are no longer available through Uniden, We apologize for any inconvenience this may cause. You can try doing a reset on the base to see if this resolves the issue. If it does not we would recommend purchasing a new telephone. BASE RESET
1. Disconnect the AC Adapter from the main base.
2. Press and Hold down the Delete Message key the main base.
3. Reconnect the AC Adapter while holding the Delete Message Key.
4. Wait for the long beep tone.
5. The base message counter will display "88" then "P"
6. Press the Play/Stop key on the main base and the Message counter will go to "0".
Hope this helps but I had to buy a new telephone. At least this came from a Uniden Support Tech.
完成的
I just had the cable company who provides service to the phone look at the problem and we determined that it was the socket that the phone plugged into (in side the house), that was wrong. There was no dial tone coming out of the phone and that was the cause of the Check Tel Line message, we plugged into a different telephone jack and the message went away. Just thought you would like to know.
完成的
显示更多的1条评论
添加一条评论
see the message I put under comments
这个答案有帮助吗?
得分 0
添加一条评论
Check the Tel line connecting the phone to your modem. Make sure it is connected to either Phone1 or Phone2 and not DSL
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anne Cascio 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 35
过去 30 天: 123
总计 41,098
