跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
Why I can't activate my touch id and home button is heating up?
I was just about to unlock my iPhone 6s, when I placed my finger on the home button I felt something hot (but the home button works well). I unlocked my phone then the home button has cooled down. I found out that my touch id has been turned off and my fingerprints are all gone then I tried turning it on again but it didn’t work. I reboot and restart my phone, I get notification that the phone is unable to activate touch id. The add fingerprint is disable on the settings. I found out that when my phone is locked, it will heat up but then when I unlock it, it will cool down after a few secs. It doesn’t work with “RESTORE” option.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Internal short. Go to Apple for repair. It is basically impossible to repair this by anyone else.
这个答案有帮助吗?
得分 4
7条评论:
Hi, what is the possible reason for internal short?
完成的
He's right. Only Apple can repair this, at this time. No one else can fix it
完成的
Liquid damage on the home button causing short or home button literally pressed down way too hard.
If it was liquid damage my guess is probably sweat seeping in?
完成的
A thousand things can go wrong, like liquid or solid debris damage, or random failure.
完成的
By the way, why this damage affects my battery?
完成的
显示更多的2条评论
添加一条评论
Sounds like a short in the button. Could be caused by moisture. I would advice you to open the phone up and change the button, in the process you can look for the LDI's and see if they have change colour to red, indicating liquid damage.
Just note, that by changing the button, TouchID functionality is gone for ever.
这个答案有帮助吗?
得分 2
2条评论:
Hi! Where to find the LDI?
完成的
You can find one without opening the phone here:
https://support.apple.com/en-au/HT204104
Inside the phone there will be multiple liquid damage indicators.
They are usually circles / stickers that are initially white and turn red when they have been in contact with moisture.
完成的
添加一条评论
添加你的答案
Celine Castillo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 2,351
