跳转到主内容
The first phone in the Redmi Note series, released in July, 2014 and produced by Xiaomi. The Redmi Note TD-LTE 2014022 was the first Redmi phone to feature the large 5.5 inch display.
15 个问题 查看全部
Touchscreen does not accurately respond?
The touchscreen often does not respond to touch and will sometimes require multiple taps or swipes to perform a function.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
7条评论
touch ways jumpering
完成的
Automatically touch display problem
完成的
Mine doesnt work at all, sometimes it work for a couple of hour or days and stop working for a couple of days even a week
完成的
my New mi max 3 touch does not work
完成的
i’m having the same problem with my redmi 7a, any progress with your device?
完成的
显示更多的2条评论
添加一条评论
4个答案
最有帮助的答案
Hi! I had this exact same problem but I ruled out a hardware issue because every time there was slow to none response, if I turned the screen off and on again, it would fix it. I looked for a solution and after trying many, many things I discovered the problem was that I was using the Full Screen option offered by MI, i.e. the option to remove the three main buttons at the bottom of the screen (Back, Home and running apps) and to control the phone with gestures. After going back to the classic three button style, I restarted the phone just in case and I haven't had any more response issues in two days, I think it was a success!!
这个答案有帮助吗?
得分 2
2条评论:
hi are u still facing the problem?
完成的
I also face issues that sometimes many apps does not respond a after a while an error occurred that app is not responding sometimes I recieved that ui not responding
完成的
添加一条评论
If the touch screen is still responds to touch sometimes, it may be a software calibration problem rather than a hardware problem. To calibrate the touch screen, follow these steps from the troubleshooting page.
这个答案有帮助吗?
得分 1
1条评论:
It started after i updated to miui 10 or thhe update before it.. now i am stuck and cannot downgrade my phone rom! It sometimes don't detect the touch, for a second or two.
完成的
添加一条评论
Your phone may be crashed, try to restart your phone or get a factory reset to have a try.
这个答案有帮助吗?
得分 1
1条评论:
still not working
完成的
添加一条评论
Before that, see the video below and know that Redmi Note 8 pro has both touch and heating issues. Check whether your phone also has these.
The problems on Redmi Note 8 Pro are touch issue and heating issue.
The first issue is the touch issue on Redmi Note 8 Pro, which I had noticed quite unexpectedly. Redmi Note 8 Pro display is sometimes unresponsive along the edges of the screen. I had thought that this touch problem would be a bug or defect on my device, but came to know that a lot of people have experienced this too. This might be due to the cheap quality touch digitalizer used by Xiaomi on this phone.
The second issue is the heating issue on Redmi Note 8 Pro. This phone was widely advertised by Xiaomi as a device with liquid cooling to prevent overheating of the phone. However, after playing PUBG mobile for a short while in an air-conditioned room, the phone started heating up. On testing, it showed a temperature up to 46 degree Celsius !
https://m.youtube.com/watch?v=0elP5IqZ-n...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Slater Stewart 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 109
总计 41,746
