跳转到主内容
The PowerBeats2 Wireless Headphones by Dr. Dre is a set of in-ear headphones designed for the active user.
7 个问题 查看全部
wont turn on after charge
my powerbeats2 will charge,and show the red LED, but when i take them off the charger, they turn off and won't turn on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Most likely battery is worn out and needs replacement.
这个答案有帮助吗?
得分 1
添加一条评论
I had the same problem and I fixed it, well kind of. The only thing that I did was to plug them to charge for like 5 minutes and the i just unplugged them an I tried to turn them on right after unplugging them and it worked, Idk if it will work for you but is worth to try it I guess
这个答案有帮助吗?
得分 0
1条评论:
WOW - you are a genius!!!!! I've tried everything and searched everywhere and this worked.
完成的
添加一条评论
添加你的答案
Evan Gunny 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 12,282
