跳转到主内容
海尔制造的笔记本电脑的维修和支持指南。
120 个问题 查看全部
My laptop is not connecting to any Internet.
I have hair i3 prime minister laptop. It is not connecting to any WiFi or evo net. It is actually connected but it's showing 'no internet, secured'. My WiFi is working on other cell phones, only my laptop is not working the same internet. Please help me with it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
10条评论
Have you tried to restart it?
完成的
Try connecting through ethernet
完成的
You need to find out whats going on before making an answer
完成的
Exactly. This troubleshoots it. The goal is to see if it is the computer's WiFi chip's connection or the router.
完成的
then make this a comment. troubleshooting steps are comments. Answers are when you know whats wrong and how to fix it.
完成的
显示更多的5条评论
添加一条评论
2个答案
已选择的解决方案
If your computer connects to the WIFI but shows no internet connection then check the name and password you used. Check to see if the connection is automatic or if it needs to be set to a particular protocol. You can also try deleting the connection, rescan and connect to it again. Also, try updating the drivers for the wireless device.
这个答案有帮助吗?
得分 4
添加一条评论
Hello,
You may find your solution here on internet connectivity on your laptops.
https://www.buytvinternetphone.com/blog/...
Moreover, once I got an issue on my internet connection so I called Spectrum Customer Service and with in no time, they resolved my issue. So i would recommend you to check your internet connection to make sure if its working completely fine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pirh khan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 9,339
