跳转到主内容
PS4 控制器型号 CUH-ZCT1。这款由索尼电脑娱乐公司于 2013 年 11 月发布的六轴 3.7 V 锂离子电池控制器维修起来并不复杂。(注:拆解指南不适用于此型号)
Sync Issue and Buzzing Noise coming from controller
Hopefully someone else has come across this issue.
When powered on the controller has a buzzing noise coming from the speaker area. It will not sync with a PS4 or Computer via bluetooth.
Tried resetting the controller via the small reset button on the back, doesn't make a difference.
It works perfectly when connected via USB but the buzzing noise is still there.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
For anyone with this issue, it turned out it was an incredibly good fake controller. Weight was nearly identical, everything looked legit but on disassembling it it was clearly a fake. If you have the same issue your controller serial number is also likely 11201371012310 - turns out lots have the same serial number.
这个答案有帮助吗?
得分 0
2条评论:
well turns out mines fake
完成的
My controller was fine until I dropped it
完成的
添加一条评论
添加你的答案
Brendan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 6,764
