跳转到主内容
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
66 个问题 查看全部
Why does the screen flash when I try to turn the laptop on?
Sometimes when I press the power button the screen of my dell inspiron 1545 gives a short, bright flash like a strobe light. It's done it a couple of times before but always recovered and managed to boot but this time it's stuck doing it. I took the battery and HDD out and put them back in again, this didn't fix the problem. The LED on the charger is green and everything seems normal with that. The screen will flash with either power source; just battery or just charger
Is there any way to get it back up and running?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi,
Is the display 'normal' when you access the BIOS menu area by pressing F2 on boot?
If so can you boot into 'safe mode' and see if the display is normal as well?
完成的
Unfortunately there's no boot whatsoever so I can't access the bios, there's only the strobe flash of the screen. To be honest I think it might be time for a replacement laptop
Thanks for the response
完成的
添加一条评论
1个答案
最有帮助的答案
Im having the same is issue, the solution is to change your battery
这个答案有帮助吗?
得分 1
2条评论:
if this does not work, it may be a hardware issue; let me know my solution does not work
完成的
The battery normally wouldnt cause this. One easy solution is to remove it and test it without the battery just plugged into the wall. If it works then its the battery, if it does the same thing, there is other issues
完成的
添加一条评论
添加你的答案
lipase 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 244
