跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
iPhone 5 died and not charging up
Hello
I have a iphone 5 that dont charge
It died and i plugged it in like i normaly would but its stuck on the battery icon overnight and still not turning on
I have tried heating the battery and changing the charger port any help thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If the screen is showing that the lighting cable is connected and the battery will not charge or hold a charge i would say replace the battery! :)
这个答案有帮助吗?
得分 0
1条评论:
Just to clarify the low battery screen should not show a plug lightning cable icon while the cable is plugged in. It should show the battery icon ONLY.
If it shows battery icon ONLY then it means the phone detects the charging cable and the charger is providing power successfully to the phone.
Which means like @vrqueen said, suggest replacing the battery.
完成的
添加一条评论
添加你的答案
Azeem Moh 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 374
