跳转到主内容
加入维修社区 - 创建账户
新 Nintendo 3DS 是 3DS 产品线中第一款大幅更新的迭代设备。在日本于2014年10月发布,北美市场于2015年9月发布。2015款 3DS 改进 3D 显示性能,全新 C 摇杆,内置 amiibo 读写功能,以及全新的4肩键配置。
3DS won't turn on, charging light turns off after a few seconds
Okay so my friend gave me this busted New 3DS (the non-XL model) and we fixed it except for one part, and I ended up frying the button board by being lazy and putting the battery in backwards while avoiding closing the case all the way to test it. I replaced it, everything worked fine, then I gave up on fixing the HOME button, and pulled out the foam I had been using to try to push the ribbon cable clasp down. As soon as I did that, it stopped turning on, and I'm getting the same symptoms as when I had fried the button board: power button doesn't do anything, charging light turns on but doesn't stay on for more than a few seconds. Battery had been fully charged when it had been charging.
It can't be that I fried the board again, I didn't do anything that could have done that. I'm not sure where to test it with my multimeter to see if I did blow a fuse somehow.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi, I also have his problem. What can I do? I replaced the top screen and I reassembled the device, connected EVERYTHING and it did not want to power on anymore but the orange light stays forever.
完成的
添加一条评论
1个答案
最有帮助的答案
If you placed the battery with wrong polarity you blow one the power line fuses (F1 or F2).
Just replace it and it will be 100% functional.
Regards,
Juan
这个答案有帮助吗?
得分 1
1条评论:
Where are those fuses located? They don't seem to be labeled.
The thing is, I blew the fuse on my old board, then replaced it. I didn't put the battery in wrong with this one, and I did nothing between it working and not working that would have blown a fuse, as far as I know. I'd like to confirm that a fuse got blown somehow before I go buy a second replacement one of these.
完成的
添加一条评论
添加你的答案
Rika 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 4,510
