跳转到主内容
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
simple way to remove LCD withoud cracking it
I have seen countless comments about the LCD breaking when trying to remove it from the LCD shield with adhesive. I have found a simple solution. Once the 4 screws have been removed take a piece of fishing line (longer than the iPad) and simply run it beneath the top of the LCD from one side to the other. Once it's in place, gently pull it down applying equal pressure from both sides. The fishing line will break the adhesive in the process, freeing the LCD. It has worked for me every time.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
What I GREAT Idea! Thank you for your input.
完成的
添加一条评论
1个答案
here is your Answer
iPad Mini Wi-Fi 版 LCD 屏幕更换
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bababooey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 187
