跳转到主内容
The HP LaserJet CM1415fnw is a multifunction color printer produced by Hewlett Packard.
19 个问题 查看全部
Printer misses information on page or isn't transferring info
My printer has started to make a very loud crinkling noise and is missing part of printed field. Most recent document was only 40% visabje and not all aligned. In inspecting the rear opening, there is a very loose and damaged plastic sheet/roller cover that I see.
Can it be fixed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@dgpagel ,Doug, 1st link is the HP support site where you may find a authorized service/support. 2nd link is a site that sells HP replacement parts and if you see the plastic sheet/roller you require for replacement click on it and a exploded parts view will come up which may aid in the installation if you want to attempt the repair. Tried to get you a free service manual, the 3rd link is to be your manual but when I downloaded it came up as 1410 model, may be the same, not sure and the 4th link wanted $5.00 for service manual. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www8.hp.com/us/en/store-finder/in...
http://www.printerworks.com/Top-LaserJet...
http://www.feedroller.com/store/Service%...
http://copynews.net/hp-color-laserjet-cm...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Doug Pagel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 82
