Why my tv has No sound
sound is intermitten.tv only months old. 32'' element tv
Hi @leon1 ,
Have you tried using headphones (if there is a headphone socket) to listen if the audio is OK or not there?
What is the audio source for the TV, antenna signal, HDMI input, Composite or Component input etc?
If it occurs on only one type of input check the output of the device that is sending the signal, e.g. set top box or PVR etc. by connecting it to another TV if possible (except antenna perhaps, if it is faulty the video should be affected as well)
If it occurs on all types of inputs and in the headphones as well, since the TV is only a few months old (from new?), verify the purchase date as printed on the TV sales receipt or proof of purchase document and then consult the warranty statement that came with the TV documentation, first to verify the warranty period and if it is still valid, as to what you have to to to make a claim for a warranty repair or replacement.
这个答案有帮助吗?
If you have picture but no sound
这个答案有帮助吗?
I jus installed power board and now I have no sound everything else works
Today 12-24-2017,
I have an Element 42 inch. Picture with no sound. Well, I finally called the cable company and after 1 minute flat the sound was back on.
On the cable remote (upper left corner right above the yellow triangle) click Settings, scroll down to Devices hit ok, then a Settings menu appears, select Audio Output Format, then select HDMI or whatever you'd like the sound to play from. Wow after less than one minute sound is back. I hope this helps someone. I spent about an hour reading and trying different things to trouble shoot and fix the sound. Wow SMH...
这个答案有帮助吗?
Thank you this was helpful
Thank you! This was helpful
My element flat HD tv all of a sudden lost volume so I turned my receiver off for 7secs as instructed on this page then turned it back on and volume was back like it never left
这个答案有帮助吗?
My element tv cuts all sound doesn’t come back on until I unplug and plug tv back in
这个答案有帮助吗?
so a lot of times the problem is when you have multiple remotes see the cable remote controls volume for the cable box so that has to be all the way up and unmuted
这个答案有帮助吗?
This happened to my mom, who has an 18” Element TV. I went into the Settings >>> Audio >>> and saw the language was set to “Spanish”. If the broadcast is not in Spanish, no sound will come out. So, switch to the language the program is broadcast in, and all is OK.
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 78
总计 102,413
6条评论
Thanks......We went to sleep with sound & woke up to no sound but thanks for putting step by step instructions.....
由 Nicole Kassay 完成的
When i turn my Finlux 32 inch tv on , i have sound but after some times the sound stop and dont come back on till i turn it off then put on before i can get sound again , so how can i fix it
由 kamstephen52 完成的
hi.are you fix problem
由 uefa87 完成的
Help! I turn volume up and it turns it's self right back I turn it back up and it goes right back down all by itself
由 mistee086 完成的
Was playing xbox one left for a min came back sound was gone, would cut in and out for a few times then nothing, every now and again it would come back with a little static in the sound cut out again, all my devices are hooked in with hdmi, think mine is completely messed up.
由 darkclown1232002 完成的
显示更多的1条评论
