跳转到主内容
Repair information for the Fitbit Charge HR. Released in January of 2015. Model numbers: FB405BKS (small) and FB405BKL (large).
66 个问题 查看全部
My Fitbit doesn't charge and I don't know why
Hi , I haven't been using my Fitbit for a while, last week I wanted wear it but obviously it was run out of charge. When I plugged it in nothing had happened and it doesn't get charged somehow and I don't know why and how to make it work. What can I do??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Noorjan, If under warranty return for repair/replacement/refund. If able to try a different compatible charging source cable/charger to rule out faulty charger. You may want to try changing the battery as it may be faulty. Battery replacement guide link below and link for battery which you can do a search for also for better pricing perhaps. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Fitbit Charge HR 电池更换
http://www.ebay.ca/itm/Brand-NEW-LSSP-LI...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Noorjan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 152
