跳转到主内容
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
307 个问题 查看全部
Red dot blinks 11-12 times
My Xbox 360 slim will not boot up after turning it on on the green button turns red and blinks about 11-12 times with a loud fan noise then shuts back off. I have looked everywhere for a fix for this and have found nothing except people with the same problem. This video is exactly what mine does and there have been no fixes for it yet. https://www.youtube.com/watch?v=yMwajymV...
I have no warranty and already taken it apart to clean it but it really did nothing. Does anyone know how to fix this? I would be super greatful for a solution.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
I got the same problem. The overheating is the issue. I replaced a few bad resistors from the link below and it worked for me.
https://www.youtube.com/watch?v=bNEsEkrn...
GL,
Kevin Tran
这个答案有帮助吗?
得分 3
2条评论:
Mine makes the sound but without the fan or the lights coming on. I tap the power button and nothing happens
完成的
This definitely works for the blinking red dot failure. However, whoever tries to do this fix, know that you are getting into a really REALLY precise soldering work. You'll need a fine tip for your soldering iron, a really good set of eyes or a big magnifying glass/bench mircoscope, and a very steady hand.
Thank you for pointing into the right direction, Kevin!
完成的
添加一条评论
I have an Xbox 360 s with the Kinect. 1439 is the model. I had this same exact issue except our light blinked about 30 times while the fans ran fast. I checked all of our resistors and 1 of them resistor 407 had about 100 ohms. I added a drop of solder to jump it and checked it with a meter again and it said 0 ohms. So I plugged it in and she is all backup and running.
The video posted above helped out a lot.
Hope this helps you out.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Shian Lawson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 31
过去 30 天: 96
总计 16,548
