跳转到主内容
track pad and select button non responsive
no matter what I try my ipods trackwheel and select button will not respond when i push them. Ipod was dropped into water for a total of no more than 5 seconds. no water came out so I'm not sure if any went in and none wanted to come out or what is wrong but if anyone has any information about how to fix it it would be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Jake,
Did you wait and be sure it was completely dry before powering it on? A bag of rice for a week usually does the trick. The worst thing that you can do is the first thing you want to do. (instinct!) The click wheel can be replaced if the unit powers on but doesn't let you manipulate it with the controls. It is not an easy process and you have to replace the back as well since when you remove it, it will get bent up. Order a new case, new click wheel and iPod adhesive and follow the teardown:
iPod Nano 3rd Generation Teardown
When you get to the second page you see the click wheel assembly is out. Then put it back together. Good luck and let us know how you do!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jake glover 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,344
