跳转到主内容
该机型使用非 Unibody 一体成型机身,使用 Core Duo 及 Core 2 Duo 处理器。
broken connector for the camera and FaceTime
The silver connection for the camera cable has broken off at the board. Is this fixable on a MacBook pro A-1398? If so where can I buy the connector. Its a flimsy connector that takes very little to displace from the board.
Ever since this happened my fans continue to run at high speed. I have attempted on several occasions the recommended resets by apple but this hasn't solved any of the issues.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
Did you figure anything out? Happened to mine as well. Thanks
完成的
Melted the connector. No sucess
完成的
添加一条评论
1个答案
I am assuming that you have a 15" Retina MacBook Pro model between late 2013 and mid 2015 - you wrote A1398 in the question but chose a different model to file the question under.
You can replace the connector, however, this will require soldering equipment and some experience with microsoldering. You can buy the replacement connector here: https://beetstech.com/product/isight-cam...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kevin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 535
