跳转到主内容
加入维修社区 - 创建账户
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Error 27, won't restore in recovery or DFU.
So I got this iPad from my elementary school computer teacher as she works with my mom. She said it says plug into iTunes and it wouldn't restore. So I tried in recovery and in DFU and it shows error 27. It had never been worked on before and has been sitting around for almost a year. What could this be? NAND?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
That's what everything is pointing to. Probably want @refectio's opinion
这个答案有帮助吗?
得分 2
14条评论:
Normally Error 27 is baseband related. Is this a cellular version of the mini?
完成的
So @refectio this brings me to an unrelated idea. The four chips and home button/Touch ID are tied by a baseband? They're programmed together. But the tying part, from my research is a baseband? So...if they all have the same firmware..then it's not like they were programmed together? But that gets discounted when you involve the Touch ID?
完成的
I'm 99 percent sure it's the wifi version because my school only buys wifi versions but I could be cellular. I will checktoday.
完成的
Yeah, I'm not really sure. I don't follow that stuff very closely as it's not something I normally do (iCloud lock and all). Every model has different requirements. My understanding is that they have a common serial number, which is what ties them together.
完成的
@refectio it is a wifi only version, should i just heat the nand first and see if it restores?
完成的
显示更多的9条评论
添加一条评论
添加你的答案
Gigabit87898 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 1,117
