跳转到主内容
加入维修社区 - 创建账户
The SwagTron T3, released in 2016, is a self-balancing hoverboard that features LED motion indicator lights, bluetooth speakers, a built-in carrying strap, and a 5-level battery indicator.
Why isn't my Swagtron's bluetooth working?
The music on my phone is not playing through the Swagtron's speakers.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
14条评论
Student iFixit Technical Writing Project
完成的
Can I say I can't believe that that's a feature of this thing! But I suppose that's why it's called a Swagtron.
完成的
My son received the swagtron T580 for xmas. It worked for a few months and now will not connect to either Android or apple products via Bluetooth. Any suggestions? I have a choice of "Swagtron music" or just "Swagtron" but this one requires a password and it keeps telling me the password is wrong but one was never given or set up?
完成的
Try 000000 this is the default
完成的
I got my SWAGTRON literally yesterday and i can seem to get the bluetooth to work, its sad because thats why i bought it
完成的
显示更多的9条评论
添加一条评论
4个答案
已选择的解决方案
To turn on bluetooth, power on the Swagtron. Powering on the Swagtron should automatically turn on bluetooth on the hoverboard. On your mobile device, turn on bluetooth, then search for “Swagtron.” Select “Swagtron” to begin connecting. The Swagtron will make a sound when the devices have been successfully paired. To end the connection between the devices, turn off bluetooth on your mobile device.
If your bluetooth isn’t working, your device may be too far away from the Swagtron. Bring your device within 10 feet of the hoverboard and wait for the devices to reconnect. If the bluetooth still is not working, try disconnecting the hoverboard from your device and then reconnecting it.
这个答案有帮助吗?
得分 3
9条评论:
It's not working
完成的
Hi just wondering if you ever found out what was wrong with your Hoverboard? I have the same issue and recalibrated the board and still no Bluetooth. I’ve only had it for two months and took care of it!
完成的
I have a swagtron t580 and had it for 2 months then the bluetooth stopped working I reset it re calibrate nothing works please help
完成的
I am trying to connect to Bluetooth but their is a six digit code and I don’t have the paper so I don’t no what to do I have the SWAGTRON T 500
完成的
Yes, that’s my problem too. I don’t have the code
完成的
显示更多的4条评论
添加一条评论
There is a separate connection for Swagtron music .
这个答案有帮助吗?
得分 0
1条评论:
that won’t show up on mine
完成的
添加一条评论
Hello everyone Heard you guys were having trouble go on the App Store and look up swag Tron it will have a picture that’s a swag Tron with like a tire looking sheep photo click on that and install it then it will show you like the miles per hour and tell you how fast is going to put in the corner want to search call me if you can just press start and it will have a picture of a Bluetooth button click on that and will teach you how to pair it then it will have the password which is 000-000 Heard you guys were having trouble go on the App Store and look up swag Tron it will have a picture that’s a swag Tron with like a tire looking sheep photo click on that and install it then it will show you like the miles per hour and tell you how fast it’s going but in the corner want to search call me if you can just press start and it will have a picture of a Bluetooth button click on that and you will teach you how to pair it then it will have the password which is 000-000 type that in and it will work
这个答案有帮助吗?
得分 0
添加一条评论
Anyone know how too turn volume up
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Emily Richter 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 70
总计 22,596
