跳转到主内容
Why the computer is on but the screen is completely black
I upgrade my Windows Vista to Windows 7 Home Premium, before that, I run Windows 7 Upgrade Adviser, it said I can run Windows 7 Home Premium and Windows 7 Ultimate. After upgrading, the computer work fine, I made a system restore just in case. After turning off the computer, next day I turned it on and the screen is completely off, the fan is on, the computer is on but the screen is blank, everything is plugged in but, pls help me
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
10条评论
Try unplugging the cable and plugging it back in at both ends.
完成的
the monitor cable or the pc box (the power cord of the pc box)
完成的
The video cable. What model is your PC?
完成的
Hi,
Is the monitor powered on?
Can you access the monitor menu options by pressing the menu button on the monitor? (You don't give a make and model number for either the PC or the monitor, this would really help us to help you!)
If you can see menu options on the monitor have you tried starting the PC in 'safe mode' to see if there is a display?
Do you see the PC's 'splash screen' , screen that shows the PC maker's name before it boots into Windows?
Can you connect another monitor to the PC to prove whether the problem is the monitor or the PC?
What have you tried to do to get a display on the monitor?
完成的
Yes, the monitor is powered on
No, I can't access the monitor menu when I press "menu" button. Model number of the monitor I think it is HP S1932 Monitor, PC Model could be HP dx2700 microtower base DT PC
The display is blank when I turn on, so I can't access "safe mode"
No, the display is complete blank, completely nothing happened when I turn on the PC
No, I didn't, but I think I will try
Don't know, it was my dad's computer, everything was set before he gave it to me, but maybe he just plug all the cables for the monitor
完成的
显示更多的5条评论
添加一条评论
4个答案
最有帮助的答案
Either your GPU or cable is bad.
First, try replacing your cable. If both support it, use displayport. If they don't, use HDMI. If they support neither, use DVI. If replacing the cable doesn't work, your GPU must be bad. Tell me the model of your PC, and if you can the model of the GPU. I will then provide a replacement.
这个答案有帮助吗?
得分 1
添加一条评论
If you cannot see the monitors menu then i say the monitors screen might be dead (or the back light). i bet if you try another monitor you'll get a picture.
这个答案有帮助吗?
得分 0
1条评论:
Does it really works? Because the problem only happened when I upgraded it to Windows 7, before I upgrade, it works 100% fine
完成的
添加一条评论
Normally a monitor have an indicator light. Is that one on or off? If no light it shows that
1 there is or no power supplied via main cable
2 Main cable defective, try an other one
3 Main switch? Some monitors have on the backsite a main switch and on the front a small on/off switch.
4 all ok above well your build in powersupply ias out of order. The display is not working anymore, so you can at least try to find a little fault, example a fuse on the power supply board or so. Check by metering if supply voltage is available on psu and output voltages on psu etc.
BE CAREFULL FOR LIVE HIGH VOLTAGES FROM MAINS SUPPLY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
这个答案有帮助吗?
得分 0
添加一条评论
Also it very well could be something as easy as the resolution. First try to boot a bootable cd/dvd/flash drive and see what happens, if it boots and the screen works, reboot and attempt to start in safe mode. As soon as the computer comes on start tapping the F8 key (7 or 8 times) and see if it gives you a screen with selection on how to start. Cursor up (or down) to the start in safe mode (without networking) and hit enter. When computer boots go to display settings and select 1024x768, apply and reboot.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
nghiagmt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 1,714
