跳转到主内容
Repair guides and support information for RCA-brand tablets.
1307 个问题 查看全部
HDMI stopped working on RCA tablet
i hooked my tablet up to my HMDI cable to my tv to watch movies threw the tv and now the HMDI cable is not working , when i plugit from my tablet i see on my tablet screen that it is connected but there is no picture showing threw the tv and i have the channel on the tv set to HDMi mode
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Mine still didn't work.
完成的
After some fiddling I finally got it to work, but since the video output has a different resolution than a standard TV, it’s pretty pointless.
完成的
I thinlk the Galileo Pro was made to fail!
完成的
添加一条评论
2个答案
已选择的解决方案
Hi,
Have you checked that you have enabled the HDMI setting in the tablet?
You don't state the model number of the tablet so I'm taking a guess here.
Go to Settings > Device > Display > HDMI Settings and enable HDMI
这个答案有帮助吗?
得分 4
2条评论:
I did that it still wouldn't display what was on the tablet to the TV
完成的
Hi,
What is the make and model number of your tablet?
Has the HDMI feature worked before OK on your tablet?
Have you checked that the TV is on the correct input?
Have you tried a new cable?
完成的
添加一条评论
Same problem, no solution for several weeks until:
Then, by chance it started working. Reason: the connector to the tablet is semi-defective, and it just happened to be in the right place at the right time -- for a few minutes. After some jockeying around, got it to work again. (It's not the cable since it works well in another connection.) Seeing the micro card connection behind, I wondered: plugging in a card helps stabilize the connection.
So, at least in this case, it is a defective, poorly built tablet, but beyond the return date. I am worried about the stability of the connection and what to do if it fails completely.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rekcurmik2002 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 5
总计 4,559
