跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 个问题 查看全部
3ds wont turn on
When I push down the button the blue light will fade on and off. That's it. This happened when I took the SD card out. Had homebrew on the SD card (I wanted custom backgrounds) and it was messing up so I was trying to fix it. It's at home charging now and I'll try to mess with it when I get home. The 3ds is about 6 years old had it since it got out. Maybe it's just old. Did I dun muff up my 3ds? Can it be fixed?
Uh oh now it won't charge. When I plug in the charger the orange light will stay on for a couple of seconds and then shut off.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
8条评论
Did you ever install A9LH or CFW?
完成的
Yea I did. I followed the whole guide on 3ds.guide it worked perfectly for 2 days before I decided to mess with it more.
完成的
Try reinstalling the OS. And next time, don't install homebrew for a costom wallpaper.
完成的
Yea, lesson learned :p. How would I go about reinstalling OS on my 3ds?
完成的
Well, I couldn't say. Maybe @tronicsfix could help with that.
完成的
显示更多的3条评论
添加一条评论
6个答案
已选择的解决方案
Got it to work. Downloaded all the files from 3ds.guide onto SD card and put in ds while holding start. It's now letting me turn it on and off freely and its charging now. Although itsome not letting me turn it one without the SD card so still working on that
这个答案有帮助吗?
得分 3
7条评论:
Your problem is you didn't go into FBI and move the arm9loaderhax.bin to the ctrnand
完成的
Now do a factory reset. You'll regret it if you don't! Also download Nintendo's repair tool from the store.
完成的
Good idea lol. Doing that now
Edit: ah crap charger is acting up again now. Even after reset.
Edit 2: if I take out the SD card ds won't turn on. Oh mannnnn
完成的
Same! My 3ds is apparently bricked, now i need to buy a new one. Maybe i should do the custom firmware again and do it correctly, and then put the sd card in. Will this work?
完成的
nigga what u downloaded
完成的
显示更多的2条评论
添加一条评论
This has happened to me. You shouldn't have done a reset. You need to follow 3ds.guide again and pay close attention to the steps after you install FBI and Luma. You should have copied the arm9loaderhax.bin from your sd to the ctrnand in FBI. But hey, who am I to tell you how to fix it? I've only fixed the problem on 5 different consoles. Take the answer or don't, but this is how I fixed mine.
这个答案有帮助吗?
得分 3
1条评论:
Some one stoled my laptop and my SD card, my 3ds is not working
完成的
添加一条评论
System reset. I'm telling you.
这个答案有帮助吗?
得分 2
3条评论:
The reset didn't help at all :/ but I still have hope! But kinda feel like I'm beating a dead horse.
完成的
Did you download the repair tool?
完成的
@Bumbum Boop: ikr! its not working i feel annoyed and sad
完成的
添加一条评论
This happened to me and i almost $@$* myself.
Luckily within about 10 seconds it powered on.
you should probs charge it.
这个答案有帮助吗?
得分 0
1条评论:
Dont work trust me
完成的
添加一条评论
Just saying had problem used godmode script to copy la files to Ctr nand works flawless
这个答案有帮助吗?
得分 0
添加一条评论
sooo um also having this issue, following the updated instructions. right after b9stool is where it started doing this.
这个答案有帮助吗?
得分 0
2条评论:
Hello can someone on this web help me
完成的
I have a 3ds it wont turn on only the blue light is on and goes of when i turn it on
I intalled homebrew
Fbi and cfw
完成的
添加一条评论
添加你的答案
Bumbum Boop 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 118
总计 32,826
