Flash light is too dim starts out bright then dims in a second
LED light too dim, how to make it bright, why does it work only on strobe...
I have found that most Blu phones Ive dealt with have problems with there flashlight apps . The one I find that does work is a security and tool app called 360 security. Once installed you will find the flashlight on the notification page. there is only on and off so it doesn't strobe or dim.
https://play.google.com/store/apps/detai...
Hope this helps
这个答案有帮助吗?
You may also want to check that you have enough battery to operate the light . If your phone is below 50% battery the flashlight wont work
过去的24小时: 1
过去的7天: 1
过去的30天: 4
总计 392
Are you talking about an actually flash light or a phone flash light?
由 Tahliyah Stafford 完成的
The phone flashlight. When it first turns on it is bright but then it Dims and becomes too dim to see anything. I've tried different apps but nothing seems to help. Thanks for any advice. …..
由 metgutchamorro 完成的
