跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
battery not charging but MacBook runs fine when plugged in
I damaged my keyboard some weeks ago when cleaning (foolishly used a wet wipe rather than an alcohol wipe and damaged some keys). I used the computer for weeks with an external keyboard and during that time the battery and charging circuit worked fine. I then completed an upper case replacement and got the internal keyboard working fine. But now the MagSafe light is very dim and the battery will no longer charge. The computer works fine when plugged into the power adaptor. Under system report the battery is shown as present (showing cycle count an such) and the AC charge is shown as connected. But battery charging is listed as "no"
I have tried resetting the SMC following the recommended procedure and also tried resetting it by disconnecting the battery for some time and holding down the power button for 10 seconds. But none of this worked.
I'm guessing I damaged the MagSafe DC-in board when replacing the upper case (although there were no obvious problems during that repair). But wondered if there is any other simple debugging I can do before I make that second repair. Don't want to miss some easy fix and don't want to bother with the DC-in board replacement if there is a larger problem. For now the MacBook is working find as a desktop :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Have you tried looking at what coconut battery says?
完成的
Didn't know that utility, but just downloaded it and it shows:
92.4% of design capacity
cycle count 321
status good
temperature: 78 F
charging with 0 watts
power adaptor connected.
Current charge is only 1.5% since the battery is run down and not charging
完成的
添加一条评论
1个答案
已选择的解决方案
It does seem like your DC-in board is bad. Remove and Inspect the motherboard closely to see if you see any burnt, missing, or damaged components. If you dont, put it back together and sometimes that will change things. If it doesnt, get a new DC-In board. MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board图片
产品
$9.99
这个答案有帮助吗?
得分 1
3条评论:
Thanks for the suggestion to inspect and reassemble one more time just in case I had some contact loose. Then if that doesn't work, time for the replacement part.
完成的
Hi Ron, I know this is a really old post but did you end up purchasing a new dc in-board? I am running into the same problem myself.
Many thanks
完成的
Minh, I should have posted last year to close this out. I opened up the machine one more time and check the connections on the upper case. I found no obvious problem but after reassembling it the charging system was working. So I decided to leave well enough alone and be happy even though I don't know for sure what changed.
完成的
添加一条评论
添加你的答案
Ron 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,737
