跳转到主内容
iMac 21.5"(Intel)維修指南及客户支持
2136 个问题 查看全部
iMac 2011 21.5 / Screen Blinks When Tilting Display
I have a strange issue with this iMac.
When I tilt the display downwards, the display goes off for a second then comes back on - it blinks.
I reproduced the anomaly multiple times by simply tilting the display down, without fail it will blink. It seems as if the display is shutting off and then turning back on again.
I recently installed an SSD following the iFixit guide, could something I have done caused it, has anyone heard of this rare issue and is it resolvable?
If it's unique and I don't have any answers I will open it up again and check all the connections are sound etc.
Additional details: It only blinks while tilting downward not up. The display will always blink back on regardless of position.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Issue is resolved.
Disassembled the iMac again and removed the logic board completely this time. Reseated everything being careful not to trap any wires and making sure all connections were routed through the correct gaps. Also used a more suitable and shorter sata data cable for the SSD (Akasa proslim 30cm sata 3.0 which is low profile and perfect for this function) .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
progen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 82
