跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
Home Button will not work after replacing digitizer and screen
Ok, I know I must have done something horrible to the connection of the Home Button when I replace the broken digitizer and screen. But for the life of me I don't know which part to replace to make the home button work again. I must have damage it when I peel off the front screen with a spudger and a hair dryer. Somehow I must have damage the cables. So my question is: Which component do i replace? And where can I purchase that component? By the way the screen and digitizer works perfectly now. But the Home Button who was working perfectly prior to the repair is no longer functioning.
Please help. thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Sometimes when i replace a digitizer, i will accidentally bent one of the home button contacts out of place... check the "metal prongs" coming out of the backside of the lcd/digitizer assembly, they should be straight and be sticking out enough so that they can touch the metal pads on the dock flex cable. Also i like to scrape the metal pads on the dock flex cable a little bit to get a better connection.
- you can test wether the problem is the dock cable or the home button by bridging the home button pads with a paper clip, while the screen lcd is plugged in you should see the iPhone act as if the home button was pressed if the dock connector/logic board is working fine. home button contact pads should be to the Right of the text "J3".
这个答案有帮助吗?
得分 4
3条评论:
I totally snapped off the contacts...Do you know what the cable is called that the connectors are on?
完成的
i dont understan, is there a picture?
完成的
Top answer .. worked a treat
完成的
添加一条评论
Try this solution first! Only takes a few seconds. it worked for me!!!
Home button sometimes not working
-Jeff
这个答案有帮助吗?
得分 0
添加一条评论
This answer is totally wrong. contacts from home button refer to later models past iPhone 5. iPhone 1gen (2g) had fixed cable that includes charging, home button and mic leading directly to its mainboard. if home button doesn't work its probably the cable's fault or connector in mainboard.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
nsolis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 44
总计 63,994
