跳转到主内容
加入维修社区 - 创建账户
具备 Wi-Fi 功能和前置摄像头的安卓平板电脑。
Why is my tablet powering on but stops in the middle of the loading?
When ever I power on my tablet, it does the normal turning on, but stops it's powering in the middle so it does not allow it to turn on fully. Does anyone else have this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
yes, keep it charging for 6 weeks in 20 degree heat (Celsius) and check it every day
这个答案有帮助吗?
得分 0
添加一条评论
BEFORE DOING THIS make sure nothing else works because hard resting resets everything ALL YOUR APPS PICTURES, EVERYTHING. But this is how you do in if you can't do anything else.
Start with this:
1: Press and hold the home button
2: Press and hold the volume up key
3: Press and hold the power button
Then go down two (using the volume buttons to toggle up and down)
Press the power button to select
Then use the volume buttons to highlight the yes and press the power
Wait
When you get back to the menu, hold the power for a few seconds and wait.
这个答案有帮助吗?
得分 0
2条评论:
It does no have a home button...
完成的
Try just the up and power, and hold it for a good amount of time, sometimes up to 30 seconds
完成的
添加一条评论
添加你的答案
Adrianna Yorlano 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 399
