跳转到主内容
任天堂2DS是一台掌上游戏设备,作为任天堂3DS的入门版本而开发,在硬件上与3DS完全相同,但没有裸眼3D功能
Why won't my 2ds read cartridges?
No matter what game I put in it, the device won't read it. It will play downloaded games, however.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
3条评论
Mine will occasionally recognize that there is a game card in, but won't let me play the game. Should I just clean it or could the reader be bent/broken?
Also I just checked the pins and don't see any that are out of place or missing
完成的
it might be dirty try cleaning it with a soft damp cloth
完成的
My nintendo 2ds can’t read games what do i need
完成的
添加一条评论
5个答案
最有帮助的答案
Did you just buy it? Chances are that the pins for the cartridge reader are bent/broken? Shine a light in the slot and see if this is true. There may be dirt or hair in the reader that would prevent it from reading games also. All ds models have issues with the pins breaking off if you're not careful when inserting games.
You can put a new reader in if you're handy with soldering and small electronics. Otherwise it may be best to sell it as a repairable and buy a new one.
这个答案有帮助吗?
得分 5
5条评论:
It belongs to my gfs kid. He told me it wasn't working so I decided to see if I could fix it myself. It looks like one pin is bent or maybe missing. I'll try and bend it back.
完成的
Does the reader come apart so I can access the pins better?
完成的
If even one pin is missing it won't read the games. There's a metal shield on the backside. You might be able to trim it a little in order to get to the pins better. I did that on a standard 3ds a couple of times.
完成的
I do agree with most of the previous comments.
Replace the slot-1 and try it again, 100% of cases is a bent pin.
Regards,
Juan
完成的
I've checked my game cartridges but nothing is wrong what should I do if nothing is wrong ??????????????????????
完成的
添加一条评论
My ds2xl won’t read any cartridges why is this
这个答案有帮助吗?
得分 0
添加一条评论
i tried entering miitopia but wouldn’t work tried ALL my cards not working
这个答案有帮助吗?
得分 0
添加一条评论
Try Cleaning it regularly, Forced air worked for mine otherwise you might need a new one.
这个答案有帮助吗?
得分 0
1条评论:
why not admit that nintendo dropped the ball the 2ds slots brake real easy i baby mine broke after 6-7 inserts 2nd 2ds nintendo lies say its me that nintendo need to be killed for ripping us all off all my ds work like champs baby them 2
完成的
添加一条评论
The same thing happened I have Thomas and friends steaming around Sodor on the 3DS and I have a two DS that doesn’t fold And it doesn’t even work and I got it off eBay but I was telling my mom to get it off Amazon but she didn’t listen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
falkedup 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 29
过去 30 天: 104
总计 40,781
