跳转到主内容
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
205 个问题 查看全部
My 2ds dont power on
i have a 2ds and it dont turn on, i opened it and im trying to fix it, i have a multimeter and i can see that the fuse is working, but when i check the other components dont show me charge , i put some solder in the sleep switch, and im looking the problem but i dont understand, can anyone help me with this? it charge but it dont turn on
even with the solder in the sleep switch dont turned on
could it be other component?
sorry for my bad english
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Eric,
If any of the following components is damage it will not turn on: broken lcd, loose or damaged wifi, camera flex broken, water or humidity in motherboard, any other short circuit.
You will need good working parts to replace one at the time and discard.
Good luck.
Eric,
Si cualquierd de los siguientes componentes esta danado el DS no encedera: Pantalla rota, tarjeta wifi rota o floja, cable felx de la camara rota, agua o humedad en el motherboard, cualquier otro corto circuito.
Buena suerte.
Juan
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Eric Alejo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 16
总计 313
