Moving right analog stick inteferes with the left.
Just within the last couple of weeks, when I have been playing a game like Binding of Isaac, I've found that the right analog stick is affecting the performance of the left. In particular, when going down on the right stick, going up on the left stick is slowed way down. There's a smaller effect when going up on the right stick and left on the left stick. I've tried resynching multiple times, and I've got a PC adapter, and it happens there as well. I went to the HTML5 gamepad tester, and sure enough, when pointing the right stick down, the most the left stick shows pointing up is about .75, rather than the 1.0 it's supposed to be.
You would think that would mean that moving the right stick down was also moving the left stick down, but that isn't the case. If I'm just using one stick at a time, there are no issues. It's only when both sticks are in use that the problem starts.
If anyone knows how one might fix this, I'd really appreciate it!
2条评论
I realize I'm late on this topic but I got the same problem. When I move the right analog stick it is as if I moved the left stick instead/also. It only moves up and down however. Left/right directions are not affected. I have another controller that's not affected at all by this and it seems weird if it would be a simple piece of plastic (joystick) causing this. To me it seems to be something to do with the circuitboard in the controller itself.
由 John Smith 完成的
Found the issue its a manufacturing defect on the left stick. To solve it, open controller so the sticks sensors are visible. 2. Use a small flat head to gently pry the top metal plate up on all four corners. 3. Move sticks with thumb pads attached to make sure there is smooth glide.( My problem was in far cry 5. Not anymore. ) 4. Put controller back together and get your game on.
由 Kris mitri 完成的
