跳转到主内容
加入维修社区 - 创建账户
The Lenovo IdeaPad Yoga 11S is a 2015 2-in-1 convertible laptop with an 11.6” multi-touch display.
Why is my keyboard and touch screen not working?
My keyboard isn't working and it's also touch screen and that's not working also. None of the keys work. My screen pad to scroll the arrow is also not working. It's impossible to access my laptop because nothing is working at the moment. Could that be a sensor, or what should I change to fix this? Appreciate all help! Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
In order for you to get access to you data, try using a USB keyboard and mouse. If the usb peripherals work, you may want to backup your data. Secondly, in order to assess whether the problems are hardware or software related, you may want to try to restore the OS with the restore partition or use a "live" OS like Pupply Linux. If the USB ports don't work as well, then it mostly is a hardware problem and would require you to disassemble the unit (depending on your skill level).
这个答案有帮助吗?
得分 1
1条评论:
In order for you to get access to your data, try using a USB keyboard and mouse. If the usb peripherals work, you may want to backup your data. Secondly, in order to assess whether the problems are hardware or software related, you may want to try to restore the OS with the restore partition or use a "live" OS like Pupply Linux. If the USB ports don't work as well, then it mostly is a hardware problem and would require you to disassemble the unit (depending on your skill level).
完成的
添加一条评论
添加你的答案
Armando 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 49
总计 2,567
