跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
LCD replacement and home button
Replacing the LCD on the iPhone 7 plus and the screen comes on but no touch I'd or respond to the home button.
I've disassembled it a few times and put it back together but i cant find the fault.
Any one have any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
The touch id button is connected over the 3d touch cable to the logicboard. This cable is very thin and fragile. You need to check this cable. It´s behind the metal backplate. You check out this iPhone 7 home button not working after screen replacement
Check my comment and you will see what I mean. To repair this you need to replace the 3D Touch.
这个答案有帮助吗?
得分 1
添加一条评论
Check the contact when flipping the screen back down, those two contact circles need to make a proper connection once the screen is put back on, there are two leaf clips that can be damaged opening the phone.
Hope this was helpful .
这个答案有帮助吗?
得分 0
添加一条评论
The Home button will not work when you replace a new screen even you use the old Home button, the iPhone 7 is different from other iPhones.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jaymie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 142
