跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Is it motherboard or screen
Ok here we, progressively in the past 2 months the screen swipe started to not swipe. I found hitting hit against my hand then it would swipe. I know. Ok so getting worse and then when I turned it off one last time then I turned it on it would not swipe- tried hitting the hand and no luck so swipe. Everything else is working on the phone- the phone charges, turns on screens on, off button works etc. I took it to the shop to get fixed as I thought it was the screen but they replaced the screen with another and it still did not work they said they said it was the motherboard. Has anyone experienced the same and yeh it's the mother board. I've got heaps of stuff on like us all , it can't log into I cloud because can't swipe to access any settings or anything etc. what does anyone think? Just get a new phone? Appreciate any feedback thanks for your help and hope ;)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What kind of phone is it?
完成的
I phone is 5s
完成的
添加一条评论
3个答案
已选择的解决方案
Hello Amanda, you did not mention what model of iPhone you have. From your description I am going to say it is likely the touch IC chip on the motherboard at fault. I've become aware of a problem with at least the iPhone 6 plus and the 6, that is known as touch IC disease. This problem is caused by the touch IC chip either failing or it may have cracked or cold solder joints under the IC chip. You being able to use it for awhile by hitting it against your hand and then after time that stopped working makes me lean towards a touch IC chip having cold/cracked solder joints. I've repaired a few iPhones lately with touch disease and noticed on one that if I twisted the back casing of the phone just right the touch screen would work until I twisted the back case again. That told me to check the touch IC on the motherboard. It was definitely the cause. Got the chip re-balled and it the touch worked great. I'm​ also thinking the touch IC because a new screen had the same issues where touch did not respond. So it could possibly be the touch IC chip on the motherboard that needs replaced or at least re-balled to get the touch screen function again. Anytime there is a hard drop the force can cause cracked solder joints on the motherboard. I wish you luck and hope I was helpful.
这个答案有帮助吗?
得分 1
1条评论:
Sorry yeh it's a 5s- Very helpful , thanks so much for your explaination
完成的
添加一条评论
最有帮助的答案
Yeah it sounds like the logic board. The only thing they can really try is cleaning the connections and retrying but that is a long shot.
这个答案有帮助吗?
得分 2
添加一条评论
Did they change screen or LCD screen my phone was thrown hard against wall an phone shop said its completely dead the motherboard av blown
这个答案有帮助吗?
得分 1
1条评论:
The fixer said he doesn't think its the screen because he put a new screen on and it still didn't work (swipe)they said he said it's the mother board and it also could be the screen but everything's on etc just can't swipe anything on screen
完成的
添加一条评论
添加你的答案
Amanda 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 410
