跳转到主内容
于2016年3月上市。型号 SM-G930V。
426 个问题 查看全部
How to clear sites from Google App on my Galaxy S7
I have 2 apps on my phone, one is Chrome, which is what I use mostly, and I can clear the history on this app, the other is just a straight Google App, and I can not figure out how to clear history on this app
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
Open the Chrome app .
Tap More Settings.
Under "Advanced," tap Privacy Clear browsing data.
At the top, tap the dropdown under "Clear data from the."
Choose a time period, such as past hour or past day. ...
Select the types of information you want to remove.
Tap Clear data.
Update (04/11/2017)
Under App options in the app settings you can select clear data as well if its the regular google app
这个答案有帮助吗?
得分 0
添加一条评论
If you are trying to erase the data on your google searches, the most effective way is by going to myactivity.google.com/. Here you can go into your accounts complete history, and change settings. Click on "Delete Activity By". There you can select more specific drop downs. I hope this is what you are looking for, and hope it helps.
这个答案有帮助吗?
得分 0
添加一条评论
There’s is simple way, you just need to open Settings > tap on Apps > Apps list > then locate the Google App, and tap on Storage option.
Now, tap on Clear Cache. That’s it. You don’t need to do anything else, You can do the same with other applications as well.
Update (10/12/2018)
Here's an update, you could simply use this resource: https://techshali.com/delete-cache-galax...
It explains all the required steps and provide additional things that you could consider.
I hope it heps you!
Cheers!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tom fleming 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 1,393
