跳转到主内容
This instant camera from Fujifilm now boasts a slimmer and lighter body than previous revisions. The Mini 8 helps the photographer by alerting them the recommended aperture. It also has a High-Key flash mode which helps the photographer attain soft portraits for a stunning look.
355 个问题 查看全部
Why are my pictures coming out distorted in color and leaking ink?
So i have had this forever and today i put in a new film, and for some reason, it's not working. My pictures are coming out of the top, however, they come out with ink on them and with color all over the picture. The picture that i take is not visible and the only thing that is, is the ink and the discoloration of the pictures. Please help me!
Update (04/10/2017)
here are some pictures
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
How long have you had this for?
完成的
1 day !,!!!!!
完成的
添加一条评论
10个答案
最有帮助的答案
Hey, I had the same problem and I used a different type of film.
这个答案有帮助吗?
得分 2
2条评论:
I had this problem and this worked thank you so much
完成的
Can you please recommend what films do you use?
完成的
添加一条评论
Hey Maya, I've had the same exact problem except mine turns blue and my mum bought it for me not quite long ago and after I've taken the photo it just turns blue idk what to do please help me.
这个答案有帮助吗?
得分 2
2条评论:
My camera does the same thing. I don't know what to do.
完成的
I recently bought my camera and it does this too and it keeps on auto turning off
完成的
添加一条评论
I think it has to do with the rollers. I’ve taken a film from the film cartridge and the ink comes from the bottom. When it rolls through the rollers I believe they are supposed to push the ink out. I could be wrong though but I think it has to do with the rollers.
这个答案有帮助吗?
得分 1
添加一条评论
Without knowing much about this camera at all, that sounds to me like maybe a bad roll of film? Do you have any others you could try?
Could you upload a picture of one of the pictures that isn't printing correctly?
这个答案有帮助吗?
得分 0
4条评论:
i have one other one i can try. I'll try that and see how that works. What would you suggest if the problem is still there? and sure, ill post some pictures right now
完成的
hey tried what you said and the same thing happened
完成的
Maybe something inside is pinching or poking the film? I really don't know much about this camera, so I can't offer a great answer, unfortunately :/
完成的
i have just got it today !!
OMG!!!!
完成的
添加一条评论
Hello Maya!
I have exactly the same problem, do you know from where does it come from?
Could you fixed it? The film? The camera?
Thank you.
Emeline
这个答案有帮助吗?
得分 0
7条评论:
hey! i haven't been able to get anyone to diagnose the problem. i don't know what the problem is and idk where to take it to get the answer. i really don't want to buy another one so if you figure something out, please lmk, as i will do for you as well
完成的
:( I don't know neither for the moment, I'll send the information where I bought my camera. I think the problem comes from it. Not from the films.... I'll tell you if there is an answer. Thanks to you!
完成的
awww poo!!! Alright, thank you!!! Please, whatever information you can provide me would be helpful. The information where you brought it and anything else! I'll keep you updated
完成的
A question : Did you travel by plane with these films? (Maybe They've been damaged by the X-ray scan....)
Did you try with new one just bought?
I still don't know what happened./..
完成的
Hello Maya!
For me, problem solved !
I've been to a camera shop to fix it, but at the same time I change by a new film just bought. And it's work.
The guy from the shop just cleaned inside but didn't see anything wrong. For him it was the films.
In fact, those films travelled with a friend by plane, and was not in the cabin. I think the problem is made by the X-ray for control in the airport.
What about you?
完成的
显示更多的2条评论
添加一条评论
i think that the film was over exposed and not fully developed. maybe if you try a new film or check the inside of your camera you will find the problem. Maybe the infrared blaster?
这个答案有帮助吗?
得分 0
添加一条评论
i’ve used two packs already and they all come out the same. ink all over them, and some don’t even develop. i’m scared because i’ve only had this polaroid for two months and i have a trip in a week that i want to take polaroids at.
这个答案有帮助吗?
得分 0
添加一条评论
Here is what happens to me. I really don’t know what to do. D:
这个答案有帮助吗?
得分 0
2条评论:
Your film has probably been exposed.
Did you try with another new film, not bought at the same time?
( because if it travel together, it could be exposed to X-ray for example, like for me when my friend traveled with it, but not carrying it in the cabin)
完成的
What do you mean by exposed? And also I just bought it the day before yesterday. So it wasn't the x-ray.
完成的
添加一条评论
Hi, Try charging your polaroid overnight / for several hours. Mine was doing the same thing for a while until I cleaned the rollers (located were the film is placed and on the outside where the film comes out) and charged it overnight.
这个答案有帮助吗?
得分 0
添加一条评论
You need to clean the ink that leaked out on to the roller but yeah i fixed it on my camera.... something
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maya Santiago 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 53
过去 30 天: 298
总计 33,248
