跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
Camera and compass not working after replacement
I have been trying to fix a phone for a relative of mine, and the rear camera refuses to work, even after replacing it.
Before I got it from them, I was told that "Pushing in on the camera lens would temporarily fix the camera problem".
Sounds like a connector issue then, right?
Nope, that's not what it was. After opening it up, gluing the glass lens piece back in place, disconnecting and reconnecting the camera cable, it still didn't work. However, the flash did.
Continuing on my mission to repair the phone, I ordered a replacement camera off eBay. After replacing it, the camera, and compass still refused to work, yet the flashlight worked.
What I imagine happened is:
When said relatives pushed the camera in to make it work, they temporarily pushed broken solder joints on the logic board back together, or they broke traces on the logic board.
Can anyone back me up on that assumption?
I'll try using my heat gun to reflow the joints in that case.
Thanks
-Alec
Update (04/10/2017)
After inspecting the board I found that the AK8963 Compass chip is physically cracked and broken in several places. As for the camera, I still have no idea what the problem is. Since eBay doesn't have anything good right now, it looks like this is my best bet:
[关联产品丢失或禁用: IF118-030]
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Don't use the heat gun; that will destroy it. look at the board under a microscope or if you have very good eyes you can look at it without one. Check for missing components or damage to the connector.
这个答案有帮助吗?
得分 4
1条评论:
I'll try doing this and see what I find.
Thanks for your advice!
完成的
添加一条评论
添加你的答案
Alec M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 142
