跳转到主内容
LG的旗舰智能手机,具有独特的滑出电池和可拆卸的I/O模块,支持多种硬件扩展选项。发布于2016年4月。
146 个问题 查看全部
Outer Screen Glass Replacement or Digitizer Replacement?
My daughter dropped her LG G5 and the screen is cracked. I've looked online and I see parts available are the Front Outer Screen Glass Panel Lens Replacement and the LCD display Digitizer Touch Screen Assembly.
Which one do I need to replace?
There only appears to be cracks on the screen. The touch functionality appears to be working fine even in the areas that are cracked, and all images appear to be displaying fine as well.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
https://www.youtube.com/watch?v=SyP_cEpp... Thats how to take it apart and the screen replacement link is in description. You need to replace the glass but separating can be a risky risky process and its best to just get the whole assembly
这个答案有帮助吗?
得分 2
添加一条评论
Switching out the glass only is what I need to do also. From my understanding it's a very difficult task. Your better off getting the digitizer with glass combo. It's already attached for you and can be accomplished fairly easily. When people try to separate the LCD glass from the digitizer they end up damaging the digitizer, only a pro. should even attempt it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gerhard Guevarra 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 4,035
