跳转到主内容
LG的旗舰智能手机,具有独特的滑出电池和可拆卸的I/O模块,支持多种硬件扩展选项。发布于2016年4月。
Front Camera not detected and Rear Camera distorted
So my LG G5 has this problem, the wide angle rear camera doesn't work in the camera app because the camera app thinks it's the front camera, so I have to switch to the front camera in the camera app, and it'll show the wide angle camera. The problem with this is that it's all distorted. Not only is that, but the front camera may be broken, I want to confirm here, I checked the cameras in AIDA64, and it only shows the 2 rear cameras connected, it doesn't show the front cam at all, anywhere, as if there was no front cam plugged in. I was thinking if I should replace the front camera. Can anyone confirm or anyone else have this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Was the phone damaged? And how?
完成的
添加一条评论
3个答案
最有帮助的答案
Unfortunately, in situations like this, there is no possible way to 100% confirm that this will fix the issue, unless someone has seen the issue personally before, and even in that situation, that person may have had a different issue causing the same symptom.
As a technician, my order of operations would be as follows for this issue,
1) Cashe Wipe/Factory reset
2) New front camera
3) New back cameras module
4) reflow on Camera Data Line
5) Motherboard
the most effective way to go through this procedure, would likely be to pay a technician to do this, however, if you insist on trying yourself, I would purchase from a retailer that allows returns. If you do this, you can buy all of the components, then return the ones you don't need. this will save you time in the entirety of the process.
这个答案有帮助吗?
得分 1
添加一条评论
Same problem in my mobile instead of opening front it openss. Rear wide cam…in cam it shows unfortunately stoped
这个答案有帮助吗?
得分 0
添加一条评论
I'm very curious about how this turned out for you as I'm having the exact same problem with my G5! I've searched relentlessly and all I can find are posts regarding the focus issue with rear cam. Please update on how you fixed the issue if you don't mind! Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jamesbadan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 1,168
