跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Proximity sensor iPhone6 plus
Hello Guys i have a question about my proximity sensor,
I replace my sensor to an other screen and its not workin properly anymore,
When i am making an call i use my finger to try to lock the screen and it works but when i hold in to my ear it some times go on lock sometimes it does not, can someone please help me out herr
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Usually I find out this is caused by a screen quality issue. The only fix I found was to use a better screen that would make the proximity sensor more sensitive and work properly.
Switching to a preassembled original screen will work too (If you can find an iCloud locked phone to use for parts).
这个答案有帮助吗?
得分 3
1条评论:
I have no proximity bracket placed on is that a problem? ,
In case not
is there annyway to fix this with a marker like the iphone4 ?? Or are the screens for the trash?
Or is there a possibility that i heaten the flex to long that its damaged?
完成的
添加一条评论
添加你的答案
glennjacobs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 964
