跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
Need to fix a cracked display screen
My display screen is cracked.
1. Is there any way to change the display screen and not buy the whole lcd panel?
2. Will changing the lcd panel solve the problem ( does purchasing the lcd panel include the outer screen?) or do i have to buy the whole display assembly?
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Well, you could have either cracked the glass, or the glass and the LCD panel underneath. If you can still see an undistorted image under the cracked glass, then the LCD panel is fine and you will only need to replace the glass.
You can replace just the glass with a heat gun and a suction cup:
MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Shresth Arya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 98
